Samsung 50"
Discussion in 'Displays' started by Joe Co, Sep 14, 2004.
  1. Joe Co
    Joe Co Auditioning
    Sep 11, 2004
    6
    I've found a Samsung 50" DLP at Sam's, model #HLN5065WX, significantly cheaper than the new HLP sets. Any feeling on the difference between the 2 models, and is the old model worth the money savings? The HLN sells for $2800.
    Joe
  2. BrianAe
    BrianAe Second Unit
    Dec 2, 2002
    441
    You can get the HLP for under 3000 if you look hard. The AVS forum power buy through TV authority(which I believe is still open) has it for 2899 delivered. Also, the new Toshiba and Panny DLPs are getting high regard. I would pass on the Sams deal.
    The HLP and other new units have a newer better chip which improves the picture in a number of ways including the all import black levels and shadow detail.
  3. Joe Co
    Joe Co Auditioning
    Sep 11, 2004
    6
    Brian,
    Joe
