Samsung 30" HDTV...3:2 pulldown!?
Discussion in 'Archived Threads 2001-2004' started by Rick_E, Jul 2, 2002.
  1. Rick_E
    Rick_E Agent
    Jul 1, 2002
    32
    Hola all,
    I'm looking at the Samsung 30" TXM3096WHF HDTV monitor. I've read conflicting information on this model. Some sources indicate that it DOES have 3:2 pulldown (Best Buy site), while others don't mention it. I also know there is a 3097 model, but I'm not sure what the difference is. Is 3:2 pulldown necessary on at 30" set?
    Anyone know the answer to this, or have general comments about these sets? (I know they are brand new). I dont have a progressive scan player.
    Thanks.
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    The use of 2:3 pulldown is always preferred, assuming the function performs properly and with minimal artifacting. And I believe the Samsung incorporates the feature. If not, just get a prog-scan DVD player that features 2:3 pulldown.
  3. Rick_E
    Rick_E Agent
    Jul 1, 2002
    32
    I'd like the unit to have 3:2 pulldown...the specs on the TV at the Best Buy site says that it DOES have it, but at the Samsung site it makes no mention of it one way or the other...
  4. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Hmmm, a $650.00 32" TV has a 27-28" diagonal picture that looks great using an interlaced player. If you wanted a larger screen TV, why go for something so small?
  5. Joey Helmsley
    Joey Helmsley Auditioning
    Jun 7, 2002
    6
    The 96 doesn't have 3:2 pulldown the 97's and 98's do.
  6. Lane Denson
    Lane Denson Extra
    Mar 16, 1999
    18
    I realize I'm asking a pretty newbie question considering my time here, but what exactly would be the disadvantage to not having 3:2 pulldown? I'd really like to get the 96, but without 3:2 pulldown on the set, what am I missing? (note that I'm currently only using a non-progressive DVD player)
    And am I correct in assuming that if I bought a progressivescan DVD player with 3:2 pulldown, it wouldn't matter if the Samsung had it or not?
  7. Matt Stone
    Matt Stone Lead Actor
    Jun 21, 2000
    9,063
  8. Eric_M
    Eric_M Stunt Coordinator
    Dec 13, 1999
    218
    I believe only the 3097 and 98 have 3:2 pulldown. Sears carry the 3097 and Best Buy has the 96 which I am going to check out. The sets are nice but there is a problem with the 3097 and an older model 3092 going by another post.
    I have the 3097 and you get a couple of transparent lines vertically down the screen which are most noticeable when watching something on s-video and component. I have went thru 3 sets already all all exhibit the same problem.
    Someone else on this group has the 3092 and have the same issue so I believe it is something with the set.
    I will go check out the 3096 to see if that has it.
  9. Rick_E
    Rick_E Agent
    Jul 1, 2002
    32
    I just hooked up my new Sony DVP655 progressive scan DVD player to the Samsung. I can tell ZERO difference in the picture when switching between interlaced and progressive mode. I checked this w/ several DVD's....I guess either the line doubler in the Samsung is that good, or I just won't be able to tell w/ a 30" screen. I've also come to the conclusion that the 3096 actually does have the 3:2 pulldown.
  10. Chuck C
    Chuck C Cinematographer
    Jan 6, 2001
    2,224
    So Rick, how is your new 16:9 TV? I bet it's awesome and such an attractive price! You go boy [​IMG].
  11. Eric_M
    Dec 13, 1999
    218
    If you would be so kind scan th escreen up and down, left and right and see if you notice any transparent vertical lines. There is usually one in the center and one towards the left hand side.
    It is best noticeable on s-video or component video. If your DVD player goes black when you hit the stop button, then do this and turn up the brightness some and see if you notice it. Let me know and I would be most thankful.
  12. David Susilo
    David Susilo Screenwriter
    May 8, 1999
    1,197
    [​IMG]
  13. Rick_E
    Rick_E Agent
    Jul 1, 2002
    32
    Eric,
    Yes, the lines are there, two of them. I really don't notice them, and I can rarely see them, but they are there. It's not enough of a problem for me to take the set back. I think any TV you buy is going to have one thing or another that is annoying. Anyway, I think every Samsung model of this series likely has the problem. I've come to the conclusion that they are all basically the same set.
