Samson 700 to power dual 20-39cs?
Discussion in 'Archived Threads 2001-2004' started by Greg Br, Feb 21, 2002.
  1. Greg Br
    Greg Br Second Unit
    Dec 13, 2001
    437
    I have had my dual setup for about a week, and they sound great, unforunately my amp is a piece of junk. Those of you who have the Samson amp do you feel like it is enough power to handle these subs. Does anyone know if the new drivers are still rated at 350 watts @ 4ohms? If you did not go with the Samson is there another amp in the $350 range that may be a better fit?
    Greg
  2. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    The drivers in the CS/PC could handle much more than 350w thermally all along..but in the enclosures they are in...350w is about all you'll want to pump into them.(the drivers will be limited by the excursion which is dictated by the enclosure anyway)
    If you had a 25-31(for example) and added a 25hz subsonic filter, you could probably run 500w into it without any problem at all.
    TV
  3. Greg Br
    Greg Br Second Unit
    Dec 13, 2001
    437
    So in lamens terms, you could have a speaker rated at 500 watts but the enclosures limit how much the driver will move. Why do you see these smaller type cubes have 500,700 watts etc of power then if they will never use it?
    I also am reading that to mean that a 350watt amp will make the speaker sound the same as a 500 watt amp.
    I read an interesting thread yesterday that said you could bridge an amp to like 700 watts and then run the speakers in series, what would this do with your subs and is it recommended?
  4. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
  5. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
  6. Ned
    Ned Supporting Actor
    Feb 20, 2000
    838
    Also most cube subs use equilization to boost the low end so they need more power to offset the loss in headroom.
