SACD setup question
Discussion in 'AV Receivers' started by Ben_wood, Sep 7, 2003.
  1. Ben_wood
    Ben_wood Stunt Coordinator
    Jun 21, 2002
    234
    I have a Sony SACD-capable DVD player with an Onkyo TX-DS595 receiver. I am using the 5.1 analog connection between the two components, my question is what DSP mode do I use for multi-channel SACD listening? Thanks.
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    You don't use any DSPs; you let it go through the multi-channel input on the receiver which hopefully lets the analog signal pass through without much interference.
    DJ
  3. Ben_wood
    Jun 21, 2002
    234
    Thanks David, I'll try that.
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    With this receiver, you can't use any DSPs with the multi-channel analong inputs, which is the only way to get SACD to the receiver.
  5. Ben_wood
    Jun 21, 2002
    234
    Thanks guys, ends up I had to go into the setup menu and select "yes" for multi-channel for the 5.1 CD analog input. Then select "multi-channel" on the Audio Selector button, this disables any DSP modes. Maybe I should spend more time reading the owner's manual! :b
