SACD/DVD-A player built into receiver
Discussion in 'Playback Devices' started by David Kyser, Jan 1, 2004.
  1. David Kyser
    David Kyser Agent
    Apr 16, 2002
    27
    Looking at upgrading older sound system, done enough research to see that the big problem with SACD and DVD-A is the analog connection to the amp (or receiver) especially if you have a subwoofer. You're options are:
    a)find a universal player which can handle the bass management
    b)find a reciever which converts the analog SACD/DVD-A input back to digital splits the signal (bass managment) then converts back to analog
    c)use an analog crossover (outlaw unit) between the SACD/DVD-A unit and the reciever.
    In my opinion option a) would be the only one which wouldn't compromise the music, but a universal player with flexible bass management is very expensive.
    What about a universal(SACD/DVD-A) player that is built into a reciever that way the the ouput stays digital unitl amplified. Are there any of these, one with flexible bass management?
  2. Ernest Yee
    Ernest Yee Supporting Actor
    Jun 6, 2003
    539
    Maybe you should look into the Sony AVD-S50ES, AVD-C70ES, AVD-S500ES, or AVD-C700ES. They're all digital receivers w/ digital amp sections w/ built in DVD/SACD (No DVD-A b/c Sony is backing SACD). Not sure about the bass management but it should be decent since it's all unit one roof.
