SACD / 5.1 Hook-up Question....
Discussion in 'Playback Devices' started by John Doh, Oct 18, 2003.
  1. John Doh
    John Doh Stunt Coordinator
    Jun 24, 2003
    199
    I plan on buying the Pioneer DV-563A DVD player because of it's capability to play SACD and of course p-scan and all that (and it's cheap!). I have a question about hook-ups though to take advantage of the SACD sound a swell as 5.1 through my HK 230. If I wire the channels separately (for SACD capability) to the receiver, and use the optical out to my HK receiver for movies, will the DVD player & receiver now which output to use for each format? I guess what I am asking is if there is a way to electronically switch between the two outputs for which media I am playing. Thanks!
  2. Rachael B
    Rachael B Producer
    Jun 5, 2000
    4,703
    31
    1,610
    Knocksville, TN
    Rachael Bellomy
    John, you'll simply use your reciever to switch back and forth between the 5.1 audio input (for SACD & DVD-A) and the digital input for DVD-V sound. You could listen to CD's either route. Best wishes!
  3. Brian L
    Brian L Cinematographer
    Jul 8, 1998
    2,918
    14
    610
