S-video vs SCART
Discussion in 'Archived Threads 2001-2004' started by Cagri, Dec 30, 2002.
  1. Cagri
    Cagri Second Unit
    Dec 18, 2002
    415
    110
    Hello,
    I currently use a SCART connection from my dvd player to my 32" direct view TV. When I watch movies, sound is coming from the speakers of the TV as well as my HT speakers unless I turn the volume of the TV all the way down. I guess if I hook up the player with s-video cable there won't be audio heard as s-video is carrying video signals only, but on the video side am I going to lose or gain or won't be able to tell the difference? Any input please?
  2. Ronn.W
    Ronn.W Second Unit
    Dec 16, 2002
    333
    If you don't already have an SVideo cable around, I'd borrow one or buy a cheap one first. Experiment with it, and decide for yourself. It could be a better pic, it might not be. It all depends on the equipment.
  3. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    If your SCART is in RGB mode, then you may be going backwards. But if it's not, then you probably won't notice much if any change...
