S-VIDEO Vs. RGB SCART which is better?
Discussion in 'Archived Threads 2001-2004' started by Kurt Leutfeld, Dec 1, 2001.
  1. Kurt Leutfeld
    Kurt Leutfeld Auditioning
    Sep 25, 1999
    8
    I have a VHS (PAL) video recorder and a DVD player, both have S-VIDEO and RGB output. My TV has 2 scart inputs 1 RGB & 1 S-VIDEO, which should I use to connect the VCR and DVD?
    Kurt
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Easy. Hook up the DVD player with the RGB (Component video). The DVD being a much higher-quality source will benifit more from the better connection.
    Hope this helps.
  3. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Kurt, are you sure about the VCR having S-video out? I've never seen that except on SuperVHS models.
  4. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    I, too, have not seen a non-super VHS VCR with S-video output, but it would give slightly improved tape playback. On the tape, luminance and color are separate.
    Even on S-VHS VCR's, whether the S-video output gives a better picture for tuned in broacasts depends on whether the comb filter in the VCR (using S-video cable) is better than that in your TV (using composite cable).
    If the TV accepts both RGB and component video, there is always a manual selection, switch or menu entry, to specify which.
    RGB from a VCR is for convenience. There is nothing present in the video (either NTSC or PAL) that RGB can deliver that S-video can't.
    Any one cable with SCART plugs can handle RGB or S-video but not both at the same time.
    Other video hints:
