S-video vs. Component
Discussion in 'Archived Threads 2001-2004' started by Stasulos, Sep 10, 2002.
  1. Stasulos
    Stasulos Stunt Coordinator
    Sep 9, 2002
    50
    Ok, I understand the difference between composite and S-video is quite visible. But has anybody tried switching from S-video to the component? Is it much better?
  2. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    It is better on my two sets. But not so big an improvement as going from RCA to S-Video.
  3. ChristianW
    ChristianW Stunt Coordinator
    Jun 13, 2001
    101
    The difference between the two on my setup is down to brightness. When using the component outputs the picture is brighter without changing any settings on the TV.
    Brighter pictures will look better - that's just how the eyes work. So it looks better to me.
    Having said that though, the difference is marginal. As Lew mentioned it's not as big a step as going from composite to S-Video.
  4. Andre F
    Andre F Screenwriter
    Dec 9, 2000
    1,486
    2
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Home Theater magazine compared all 3 types of connections from the same DVD player to a reference 50" RPTV. Here is what they concluded:
    Composite Video: baseline
    SVideo: 20% better than Composite
    Component: 25% better than Composite
    They also noted that for smaller display sizes, the differences were less, and the improvement was greater for bigger displays.
    Another member had a 25" tube set in his bedroom and for grins went from SVideo to component and noticed a visible difference.
    So from all points of view - Component is superior.
  6. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Yes.
    I have both hookups on my system, projected at a screen size of 84".
    The s-video is AR silver conductor, triple shielded and is 20ft long. The component is also AR copper conductor at 20ft long.
    I did some experiments using A Bug's Life dvd. When I watched it using s-video, there were very slight brown halos around Hopper's Body (bleeding) which totally disappeared when I switched to component video. There were also some colour differences with component being slightly less saturated than s-video, but the differences were small enough to be attributable to calibration variences between the two. There was also a very small increase in sharpness with the component.
