S-Video vs Component Video
Discussion in 'Displays' started by Walt H, Jul 31, 2004.
  1. Walt H
    Walt H Stunt Coordinator
    Aug 5, 2000
    209
    Is there really a difference in picture quality between S-Video and Component Video on an analog TV?
  2. greg_t
    greg_t Screenwriter
    Jan 18, 2001
    1,650
    Maybe a small difference, at least in theory. Possibly a more accurate image. DVD video is stored in component format, meaning there are three video signals in total, two chroma and one luminance. Using Component video out keeps these three signals seperate and the dvd player does not have to downconvert. So theoratically, you should see a more accurate image.
    S-video can only carry two signals, one chroma and one luminance. So, when using S-video out, the dvd player must combine the two chroma channels present on the DVD into one. So you aren't staying totally true to the source. In the real world, the difference may not be all that great, but in theory the component out should provide the more accurate image.
  3. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    There is. Weather is visible or not depends on the source material, source hardware, and the display.
    Component is three separate signals:
    Y or luminance (The Black and White information)
    R-Y (Red minus luminance)color information
    B-Y (Blue minus luminance)color information
    S-Video is two separate signals.
    Y
    Chroma (The R-Y and B-Y combined)
  4. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    Yes there is. On my 32" Analog Sharp CRT, There was a noticable difference. I watched a little of The Fifth Element and the difference was very apparant. I double checked Video Essentials and there is definitely a better picture according to the tests.
  5. Walt H
    Aug 5, 2000
    209
    Any difference between composite cables and component cables? I have a couple extra composite cables brand new. Can I use that instead of paying top dollar for component cables?
  6. Ian-Fl
    Ian-Fl Second Unit
    Jul 13, 2003
    281
    No there's no difference. Component and composite cables are both 75 ohm coaxial cable.
    On my projector it doesn't have a good deinterlacer like many projectors, therefore component cables from a progressive scan player has a much better picture than the s-video input.
