S-Video vs. Component for DVD on Analog TV
Discussion in 'Home Theater Projects' started by Dave Farley, Feb 3, 2005.
  1. Dave Farley
    Dave Farley Second Unit
    May 15, 2004
    412
    2
    My mother finally convinced my father to get a DVD player for their house. They called me up for help in getting one. I picked up a Sony DVP-NS775V for them.
    Their TV is a Sony 32FV300. It's an analog set that was bought new 4.5 years ago. Nice TV. They have no plans to buy an HDTV. This set has 2 sets of component inputs on it. I always figured this was a waste on an analog set. Money isn't an issue but I have a spare S-Video cable here. I was wondering if going with component instead of S-video would improve picture quality for DVD on an analog set?
    Thanks.
  2. ChuckSolo
    ChuckSolo Screenwriter
    Jun 26, 2003
    1,160
    It did on my Panasonic 32" although not as much as one would think. Component is always a better connection than S-Video which is better than composite. On a 32" screen a DVD is going to look pretty good anyway, as long as the DVD itself is mastered well and the film itself looked good to begin with. The aforementioned Panasonic is still in action at my parent's house and I am amazed at how good DirectTV looks on it via the RF connection. As long as you have 2 Component connections, use one. If I were you and was balking at paying 50-100 bucks on a component cable, I would just get one at Wal-Mart. I have seen Component cables at Wal-Mart for way less than 30 bucks.
  3. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    PQ will not be dramatically different, but color will be noticably improved. I've always used component whenever available.
  5. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    I'd use the component connection as well. I did on my 32". I wouldn't use the cheap cables though.
  6. Dave Farley
    May 15, 2004
    412
    2
    Thanks for the replies everyone. Component it is. Thanks for the advice on where to get a good deal on a set of cables.
    Philip,
    Thanks for the advice and the links. I realize that component is a better connection than S-Video but in my own experience I actually saw a better picture for SD broadcasts through composite and S-Video with an HD cable box. I made the mistake of extrapolating the SD cable result to interlaced DVD playback. Never having owned an analog set in the past with component connections, I always looked at S-Video as the best input for interlaced material and just figured that component input with an analog set was a case of the law of diminishing returns. It looks like I made an incorrect assumption.[​IMG]
  7. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Sometimes some of the cable channels come through better using composite.
    Component is a better connection, but then somebody has to comb filter the composite video channels. The cable box usually does a worse job compared with sending out composite and letting the TV comb filter it.
    Digital channels are much better off with component video, 9or at least S-video out of the box.
    Video hints:
  8. Dave Farley
    May 15, 2004
    412
    2
    Thanks for the information and the link, Allan.[​IMG]
