S-Video to RCA
Discussion in 'Playback Devices' started by Francois L, Mar 17, 2004.
  1. Francois L
    Francois L Stunt Coordinator
    Feb 17, 2001
    70
    How a simple RCA to S-Video adapter can convert a composite signal to Y/C and vice versa?
  2. RoyGBiv
    RoyGBiv Stunt Coordinator
    Apr 10, 2000
    229
    Radio Shack has a $20 converter which will take RCA in to s-video out and vice versa. I have used it and think it works pretty well.
    SMK
  3. oryan_dunn
    oryan_dunn Agent
    Sep 25, 2003
    37
    I think the ones you are refering to, the small 1" or so adapters that go inline, I think that those just combine the luminance and chrominance signal to the center pin of the rca and then the ground to the outside. This is purly a guess on my part, but highly doubt that there are any electronics in a little thing like that.
    Ryan
  4. Francois L
    Feb 17, 2001
    70
    Yes, these small adapters.
  5. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    It contains a few capacitors, resistors, etc. TV sets "with no comb filter" all contain a similar circuit since they too must convert composite to S-video internally.
    What it does is send frequencies approximately 3 to 4 MHz to the C (color) side and the rest to the Y (luminance) side. The frequency separation is not thorough or accurate, namely at the spec'ed boundary frequency there is considerable leakage to the wrong side while some distance from the spec'ed boundary frequency most of the signal goes to the correct side. This is an inherent characteristic of simple and inexpensive filters. Feeding the other way the Y and C will simply recombine themselves and come out the RCA jack.
    There are some variations from one brand to another for example one brand might throw away the frequencies above about 4 MHz.
    The picture quality will be about that of ordinary VHS tape.
    Video hints:
    http://members.aol.com/ajaynejr/vidcomb.htm
  6. Francois L
    Feb 17, 2001
    70
    Thank you very much, it's make sense now.
