Nicole P
- Aug 31, 2001
Firstly, thanks to those who answered my previous post in which I asked whether an S-Video to RCA cable could reduce dot crawl.
As a result of your responses, I decided to conduct an experiment with a Tandy(Radio Shack) S-Video to RCA conversion connector.
Since I am in Australia, broadcasts and most of my movie collection are in PAL. It is only when I switch to NTSC for the odd Region 1 disc that dot crawl becomes obvious. This is also accentuated by "rainbow swirls" (pardon my ignorance of the technical term) on detailed contrasting images, i.e rolling credits, silhouetted trees, foliage and grass, spectacle frames, etc.
So, I hooked up my DVD player to my TV via a standard composite cable, a standard S-Video cable and the connector mentioned above. The results are as follows:
1. Yes, the dot crawl is still there.
2. The "rainbow swirls" are gone so the dot crawl is not so pronounced.
3. The image is a little softer.
The softness is probably because of the multiple points of connection causing degeneration in the signal, but overall, I am much happier with the NTSC image. For PAL, I go back to straight composite.
Thanks again for your help, and thanks for letting me share the results with you.
Cheers,
Nicole P
Cheers,
Nicole P
