S-video to composite converter
Discussion in 'Archived Threads 2001-2004' started by Ryan Hawke, Sep 24, 2001.
  1. Ryan Hawke
    Ryan Hawke Agent
    Jul 10, 2001
    45
    Does this composite to s-vid convertor work the other way? I want to connect my s-vid out on my computer to the composite-in on my tv. Thanks.
    --Ryan
  2. Ken Situ
    Ken Situ Stunt Coordinator
    Aug 6, 2000
    102
    I think so. I think the composite out just has a non-polarized capacitor between the Y and C pins (pin 3 and 4) of the S-video connector, so it should go either way.
  3. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    I'm not sure....
    The reason I say that is because Parts Express sells a composite to s-video converter and an s-video to composite converter.....
    There may be some difference...they look the same, but have different part numbers.
  4. donovan_chin
    donovan_chin Stunt Coordinator
    Aug 6, 2001
    150
    Yes, they DO work and no, there is no difference functionally between the two parts. The only difference you get is between a female composite with a male svideo plug or a male composite with a female svideo plug. It depends on what cable you want to use. If you want to use an svideo cable, then get the one with the female svideo side. I personally use this because the signals are combined only at the last moment and is carried on separate wires throughout the length of the cable.
