IS there a cord you can by to make the gamecube s-video enabled?
May 24, 2003 #1 of 4 Eric Stuckey Second Unit Joined Mar 24, 1999 Messages 421 Real Name Eric Stuckey IS there a cord you can by to make the gamecube s-video enabled?
May 24, 2003 #2 of 4 Brian Ruth Supporting Actor Joined Jun 21, 2002 Messages 563 Eric: Monster Cable recently started making S-Video cables for GameCube, but they are quite expensive. I'm sure other third party companies make S-Video cables also, and they should be fine for most of your needs. Any local videogame store worth its salt should have some to sell you.
May 24, 2003 #3 of 4 David Lee Stunt Coordinator Joined Jun 14, 2001 Messages 72 I Believe N64 and Gamecube use the same analog cables. So try that also.
May 24, 2003 #4 of 4 DaveGTP Senior HTF Member Joined Jul 24, 2002 Messages 2,096 Indeed! N64, Gamecube, and SNES use the same analog a/v out. An s-video cable should be readily available from your local game store.
