S-Video splitter??
Discussion in 'Home Theater Projects' started by Robert_eb, Jul 13, 2003.
  1. Robert_eb
    Robert_eb Supporting Actor
    Sep 14, 2001
    965
    My monitor only has one s-video input but I have several pieces of hardware that utilizes s video inputs. Is there a s-video slitter on the market? I've looked around and cant find anything.
  2. adamKI
    adamKI Stunt Coordinator
    May 10, 2003
    107
    What you need is a SWITCH that you plug all of your S-video sources into and allows you to select which source to display on the TV. Radio shack sells an inexpensive one here.
    You can also find switches with more features such as source auto-select, remote controls, etc but they'll probably set you back more than $35.
    Good luck,
    adam
  3. Robert_eb
    Sep 14, 2001
    965
    It states in the product features that it has four inputs and one output, each with three RCA jacks and one S-video jack. So does that mean it only has one input for s video or four?
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
