Bob Mosesso
- Jan 20, 2002
Hooking up my HT system & need some adivce.
EQ is as follows:
HK-520 AV Reciever
Echostar Sat Reciever-C-Band/Composite Out ONLY
Panasonic-RV-31 DVD Player
Mitsubichi VCR-Composite Out Only
Sony 40" Wega-(it's on the way)
Here is the Question????
I only want to run 1 Video Cable if possible out of the reciever to the TV.
If I use S-Video out of the DVD & use Compostie out of the SAT reciever & VCR into the Reciever, Can I use S-Video as the only cable out of the reciever to the TV?? Other wise will the signal be converted in the reciever or will it allow it to pass through??
Another question I have is concerning HDTV.
I plan sometime in the future to retire the C-band dish & convert to the little dish with a HD Reciever.What outputs are used to get the best possible picture. Can you still use s-video or is component required??
Thought if I was gonna run cables, I might as well get this knocked out know, considering I have to go down walls, crawl under the house & back up wall to feed in to the TV. Yeah kinda of crazy set up.
Thanks in advance for your input,
Bob
EQ is as follows:
HK-520 AV Reciever
Bob
