S-Video Problems w/ Denon AVR-3801
Discussion in 'Archived Threads 2001-2004' started by Jeff Braun, Aug 21, 2001.
  1. Jeff Braun
    Jeff Braun Auditioning
    May 13, 2001
    12
    Hello, I have a question about hooking up a DVD player to this receiver using S-Video. I'm sure what I'm doing wrong is easy to fix, but I just can't figure out what the problem is. Basically, I have the DVD player connected by the S-Video cable to the DVD input on the receiver, and the receiver connected to the TV output with standard audio cable (the one with red, white and yellow connectors). Basically, I can get an audio signal from the DVD player to the speakers, but no video signal. However, when I use two sets of regular cables, instead of one regular one and one S-Video, the video signal comes in properly. I know using one regular cable and one S-Video is a stupid thing to do, and I'll be getting another S-Video once I can get this problem worked out. Anyone have any suggestions as to what might be wrong? -Jeff
  2. donovan_chin
    donovan_chin Stunt Coordinator
    Aug 6, 2001
    150
    Jeff,
    Receivers don't do any conversion of s-video to composite or the other way round. It just does the swtiching of the signals. So, if you input an s-video signal, you will output through the s-video monitor. If you put in a composite signal through the RCA jack, it will output the signal through the composite RCA monitor. Hope this clears things up.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Jeff: When my DVD player was my only SVideo device, here is what I did:
    - I ran SVideo straight from the DVD player to the TV
    - I also ran Composite (single yellow cable) from the DVD player to the receiver.
    - I ran Composite from the VCR, CATV box, DSS box, etc., to the receiver.
    Then I ran 1 composite cable from the receiver to the TV.
    I left the TV set to look at the receiver signal. Now, my wife/kids could use the entire system just by using the receiver remote to do all the switching. And we could see the receiver menu's and on-screen display through this.
    But when I put in a DVD, I took the extra step and flipped the TV to see the better SVideo signal.
    Plus: when people came over, I would fire up a DVD and toggle between the Composite and Svideo signal so they could see how much better SVideo looked. This has helped encourage 2-3 friends to wire with SVideo.
    So it's NOT a stupid thing to do. It's actually very smart. [​IMG]
