S-Video Problem on Old TV
Discussion in 'Displays' started by Alexander Kuch, Mar 7, 2005.
  1. Alexander Kuch
    Mar 2, 2005
    31
    I have an old 1991 RCA 31 inch tube TV and the S-video works fine except it's in black and white. I bought 2 new TV's and would like to be able to save my money instead of buying a new one. Any idea at all?
    Yes, I tried numerous cables that definately work on my other TV's.
  2. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,983
    6
    Is anything else hooked up to the video input. S-Video plays black & white if something is connected to the composite video .
  3. Alexander Kuch
    Mar 2, 2005
    31
    No nothing is. I have one Composite and one S-Video. The only other thing is coaxial cable for my satelite.
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Alexander, here's where you want to ask your question — in Display Devices.
    So, you're only seeing black-and-white images with the S-Video connection? You have changed cables?
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    One composite and one svideo.. As siad, are they definetly used as different inputs by the display?
    Just not sure at all, definetly a rather odd ball issue to have with a display, as in I have never seen that one before.
  6. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    Sounds like a bad s-video cable or a bad pin on the s-video connector on the TV.
  7. Alexander Kuch
    Mar 2, 2005
    31
    The only thing being used is coax in. That's it.
  8. John Whittle
    John Whittle Stunt Coordinator
    Mar 22, 2004
    185
    If the S-V connection on the set is on an input that also has a composite input, then it's likely that there is a switch built in the connector on the board in the set and it's bad or hanging up and not completing the circuit. Also it's possible that there is a bad track, cold solder joint or similar type of problem on the input board.
    If you have a service manual and (hopefully) don't have surface mount components, you might explore the board and see if you can get it to work. If you don't have a service manual or if the board has surface mount components, then it's time for a professional with the right tools.
    Then you'll have to decide if the set is worth the service call/charge.
  9. Adil M
    Adil M Supporting Actor
    Nov 21, 2001
    922
    Go into the basic menu of the TV and see if there is an option to change to S-video or activate it.
    Hopefully it is this.
    Then do a cable switch.
    If not that it's probably in the tv or the source.
    Check the DVD player.
    I hope you do not have to do all this.
