S-Video outlets on the receiver
Discussion in 'Beginners, General Questions' started by Justin.S, Nov 6, 2003.
  1. Justin.S
    Justin.S Auditioning
    Nov 5, 2003
    Hello there,
    I was looking at buying the Sony DDW750 system, but noticed that there AREN'T any S-Video input/output outlets on the receiver.
    So....
    What's the difference if:
    1) Your S-Video goes from the DVD player -> receiver ->TV
    and
    2) Your S-Video goes from the DVD player -> TV?
    THanks,
    Justin
  2. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    The difference is that when you have more components to connect via S-video than your TV has S-video inputs, you'll need a separate switcher. Until that happens, you're fine.
    M.
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    also, as far as picture quality goes, i doubt you'll notice a difference either way.
    your best bet is to simply test and see for yourself.
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    If you only have the one S-video connection, go straight to the TV. Component video, if both your DVD and TV have this connection type, is an even better choice.
  5. Tim K
    Tim K Second Unit
    Jul 7, 1999
    402
    the purpose of being able to run video through your receiver is two-fold. 1) as mentioned if you have more s-video outputs than your TV has inputs. 2) if you don't want to have to switch your TV from input to input. By allowing a receiver to do the switching, when you switch your receiver from DVD to TV the receiver switches the audio and video output. It just saves you from pressing more buttons.
