s-video or rca cable run
Discussion in 'Playback Devices' started by marc, Oct 20, 2003.
  1. marc
    marc Stunt Coordinator
    Jun 30, 1997
    88
    Hello all,
    I have a question. What is the longest run that I can have for either an s-video cable or L,R,Vid RCA cable? I have (2) tivo units that I want to connect to a dvd recorder and one is in my office, the other is in my bosses offices. They are about 25-30' apart. Any suggestions? Thanks.
    Marc
  2. BenSC
    BenSC Stunt Coordinator
    Jun 19, 2003
    190
    While I have not tested it, I asked this in another forum a couple days ago. The response was 150' ish. Or using something like the BVD-10 as shown on http://www.audiocontrol.com/multi_room.htm
    But those things are expensive.
  3. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    I have a 30 foot S-video cable running now, (I bought it from one of the members here)and it works great. You should be able to find one for good picture results. Then use coax cable with a RF to Line connectors for you sound.
  4. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    At 25-30', the best thing you can do is go with two runs of RG6, attached to s-video breakouts at both ends.
  5. Rick_Brown
    Rick_Brown Second Unit
    Oct 25, 2001
    449
  6. Jerome Grate
    May 23, 1999
    2,984
    6
    110
    That's true, my run is to a 24 inch Apex T.V. in the den. Far better than Coax, and better than composite even using an RG 6 cable with RF to line connection.
  7. Jim Rakowiecki
    Jim Rakowiecki Stunt Coordinator
    Sep 2, 2003
    162
    Have you considered an amp to gain signal before you make that long run?
    I have one by Niles that does RCA and have seen some amps that do S-video as well. You may want to look into it.
  8. marc
    Jun 30, 1997
    88
    What do you guys think of the wireless route? Like the RCA units for video?
  9. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    Those 2.4Ghz wireless video transmission systems have problems. I see even with a clear only 10foot distance there are dropouts about once a minute or so.
