S-video cable resolution?
Discussion in 'Archived Threads 2001-2004' started by Danny B, Nov 26, 2001.
  1. Danny B
    Danny B Extra
    Nov 23, 2001
    22
    Hi,
    I was told that if using S-VIDEO cable(connected to a DVD player),i will only get around 400lines(cause the s-video has its limit around the 400 lines of resolution) out of 540lines that a DVD player puts out.
    BUT if i use component cables,i will get the 540 lines of resolution!
    is this at all true? does any1 know?
  2. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    Not true. Both the S-video and component connections deliver essentially the same luma resolution of 540 TVL. However, component connections can deliver better chroma resolution.
  3. Danny B
    Danny B Extra
    Nov 23, 2001
    22
    Thanks you for clearing that up for me.
    I was worried i would not get the full 540 resolution lines by connecting S-VIDEO since that is all i can connect at the moment.
    Thanks again
  4. RyanDinan
    RyanDinan Stunt Coordinator
    Oct 25, 2000
    249
    Coposite, S and component all have the same luma resolution (black and white)- Which is good to 540 lines and more...
    However, composite and S video are limited in their chroma (color resolution) to about 120 - 140 lines respectively. Since DVD is encoded with 270 lines of color (half the luminance resoluion), you can see that composite and S only deliver about half of that. A component or RGB connection is necessary to deliver the full 270 lines of chroma info.
    -Ryan Dinan
