S- video and sub questions
Discussion in 'Beginners, General Questions' started by forest_y, Dec 2, 2003.
  1. forest_y
    forest_y Auditioning
    Dec 1, 2003
    2
    i searched and couldn't find the answer to these could someone help?
    i was just wondering what the diffrence was between the s-video and just normal a/v output and inputs were. how should i connect everything?
    i have pioneer vsx-v812 reciever
    dvd player w/ s-video and rca out
    Khl tv w/ 2 a/v and one s-video input
    also i just bought the audiosource 230 surround system
    the sub is 8' AND 100 watt. it only has the rca L and R input so i split my recievers one rca into it like your site says. But it doesn't pound as much as i'd like it to. i hooked it directly to my dvd audio outs and it plays loud. can i make this one louder somehow comming from my reciever or would it be better to get a jensen 12" 100 watt with the single imput?
  2. Johnny Ayala
    Johnny Ayala Stunt Coordinator
    Nov 13, 2003
    183
    try using the speaker outputs to the sub.......thats the way i have 2 of mine, plenty of bass. Good Luck. [​IMG] [​IMG] BTW..you said you connected it to the DVD audio outputs? How do you control the volume?
  3. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    Welcome to the forum Forest.
    S-Video splits the video signal into two parts: color and brightness (the actual terms are a bit different, but this is the concept). The regular RCA video connection called ‘composite’ carry all of the video information in a single signal. The picture quality should be noticeably better with S-Video, but it will depend on your DVD player and TV.
    Don’t expect too much from your 8”, 100 watt sub. I would recommend looking at alternatives if you are not satisfied with what you have.
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
  6. forest_y
    Dec 1, 2003
    2
    thnks
