S video and Composite switching
Discussion in 'Archived Threads 2001-2004' started by James Brown, Sep 9, 2002.
  1. James Brown
    James Brown Stunt Coordinator
    Jul 18, 2002
    89
    I just ran across a problem over the weekend. My wife has a Karaoke Microphone deal that we used to plug directly into the front A/V jacks on the tv. I tried using the front A/V composite jacks on the front of my receiver this time and got audio but no video. I have ALL my other components hooked up with S-Video and out to TV with S-Video also.
    My question is, do I need a composite video cable also going to my tv to get the video of any composite input on my receiver? I see that Denon states S-Video/Composite switching but I dont know if they're refering to taking a composite signal in and outputing a s-video signal.
    Thanks for any input.
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Yep- most receivers don't offer any ability to cross covert. If you come out of the unit Svideo, you will only be able to switch Svideo sources: and vice versa.
    So, you'll also have to run composite out from the receiver if you plan to run composite inputs.
    -V
  3. James Brown
    Jul 18, 2002
    89
    Thank you Vince.
  4. Steve Cross
    Steve Cross Agent
    Jul 4, 2002
    31
    Or get an S-Vid adapter for the composite input.
