Rythmik's DirectServo
Discussion in 'Home Theater Projects' started by MarkRoberts, Aug 20, 2004.
  1. MarkRoberts
    MarkRoberts Stunt Coordinator
    Oct 20, 2002
    167
    Any one here used heard or built one? Looking for opinions and user reviews. Either version.
  2. ross ish
    ross ish Stunt Coordinator
    Nov 18, 2002
    163
    Built a 2.5 cubic sealed box. Sub is in 12x14 bedroom. Graphed pretty flat from 17hz to 100hz. Sub just pounds. Servo does not really care what box you put it in. Naturally the larger the box the more output. unlike non-servo subs, the size and type of box does not change the low output response.
    driver is massive and the rhthmik amps are fairly well built.
  3. MattD
    MattD Stunt Coordinator
    Feb 29, 2000
    166
    Rythmik Amps are awesome for the price. I use one in my diy sub. I haven't tried the servo sub though.
  4. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    The amps are good.
    The info that the box size doesn't matter for servo use is bunk.
    The only thing servo control buys is you can use a smaller box. And limiting ability for not over driving the woofer. Sometimes that's a good thing if you have teenagers. If mature adults a using the sub then servo control can limit absolute output. Also some servo units cause audible 'pumping' sound from the woofer.
  5. MarkRoberts
    Oct 20, 2002
    167
    The reason I am interested is I used to have a mirage BPSS-210 which is a servo subwoofer and sounded awesome with music, tight and controlled. It would be for the bottom octave of my fronts not for LFE use. Had to sell the mirage for financial reasons at the time and it is no longer made.
    As for box size I would go with what Rythmik recommends. I have one of their basic 250 amps and I really like it. So I thought there servo might be worth a shot.
  6. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Mark,
    I built a sub using Brian's amp and 12" woofer with a built-in LT circuit and it sounded very good. IIRC, the box size was a 16" cube. It didn't have absolute output, but it was relatively small and went pretty low for a sealed enclosure.
    I haven't tried the servo-sub yet so I can't comment on that one.
