Mike Veroukis
Hey!
Well I bought an HTR-5450 (aka RX-V520) a while back and teamed it up with a pair of Paradigm Studio40s. I've read several postings here about how many of the lower end receivers may not deliever the full rated power when driving all 5 channels. This has lead me to believe that to help me get the most out of my speakers I should probably upgrade my receiver. Lucky for me the place that I bought it from is running a trade in special where I can trade it in for another receiver + difference in price.
So I've been looking at a few options. The Yamaha RX-V1200 and the RX-V2200 both seem like good contenders. My first question here is what are the major differences between the two receivers? I know that the 2200 has 100W vs the 1200's 80Ws per channel. Is there anything else? I did a quick check at the Yamaha site and they seemed pretty much the same to me.
The other major question I have is if I decide to get the RX-V1200 which is rated to have the same power per channel as my current HTR-5450 (80W/channel), would the RX-V1200 do a better job of supplying the rated power to all channels when they are all driven? I'd imagine that the 1200 has a better power transformer and beefier amp section and therefore it should clearly out perform the 5450 even though they are rated the same. Yes I know the 1200 is 6.1, but let's just assume I'll be running a 5.1 setup.
Here's my "buy for now, plan for later" logic. If the only difference between the 2200 and 1200 is the power rating and the 1200 does a better job of supplying power to each channel then the HTR-5450, I might as well get the 1200. Later when I get bigger floor standers for mains I can make us of the 1200's pre-outs and attach an external 2/3 channel amp (Rotel or something in that level) to drive those. Does this sound like a good idea? Any suggestions?
- Mike
- Mike
