RX-V1 preout problem
Discussion in 'Archived Threads 2001-2004' started by DonnyD, Feb 3, 2003.
  1. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,145
    I really love this piece of equipment but the constant checking for the loss of a main is getting tiresome. Last year I found that this would be a little problem to check now and then but it seems to be becoming more often. Yes, I know that inserting a rca into the preouts is a quick fix but I am needing to know if there is a better and more permanent fix?
    Anyone had this fixed or know of a simple/ more lasting fix?
  2. JohnnyA
    JohnnyA Extra
    Jan 8, 2003
    20
    yamaha can service this if you bring it in. but otherwise, yeah, you can insert and leave an rca cable in the jacks as opposed to poking the jacks with it every now and then.
  3. Keith Mickunas
    Keith Mickunas Cinematographer
    Dec 15, 1998
    2,041
    I kept having this problem with my left channel. I just left a cable connecting the in to the out. Recently I got some couplers that are used on some units, and that works fine too.
  4. Keith Mickunas
    Dec 15, 1998
    2,041
  5. JohnnyA
    JohnnyA Extra
    Jan 8, 2003
    20
    keith, if you are using the double-pin couplers from yamaha, i've heard they are not shielded. some users have found that they produce inferior sound compared with using good rca connectors. personally, i have not done any comparison with either my dsp-a1 or rx-v1, but i did opt for the rca connectors just for good measure. [​IMG]
  6. Phil*K
    Phil*K Stunt Coordinator
    Jan 23, 2003
    170
    This is off of the subject,
    I just bought a V1 and I'm using powered towers for my mains with no separate sub. I connected using the splint mono output and set the LFE to sub. Any thoughts about this.
    Phil
  7. JohnnyA
    JohnnyA Extra
    Jan 8, 2003
    20
    phil, i'm not familiar with the setup configuration of your powered towers. but generally speaking, if you want to send only bass output into them, i think the current setup is fine. personally, i would rather use the stereo split outputs to take advantage of directional bass, and set my lfe setting to "main".
  8. Phil*K
    Jan 23, 2003
    170
    Thanks John
    If you'rr talking about the split coax jacks in the back thats what I'm using and from taking to Yamaha these are mono. If you're saying to use the speaker level input, I can do that but the crossover it 150hz. I'd just rather use the 90.
    Phil
  9. JohnnyA
    JohnnyA Extra
    Jan 8, 2003
    20
    phil, what yamaha has told you is interesting news. from the manual, the split sub output is supposed to be a stereo feed, with bass derived from the main L and R channels separately.
  10. Phil*K
    Jan 23, 2003
    170
    Johnny,
    LOL, yeah never listen to the tech help. I just revisited the manual and your are right it is stereo for freq below 90hz derived from the L/R main and L/R rear. However the LFE is mono from both. I quess that would mean when you listening to a source with an LFE output like a DTS/DD moveie tract its mono. When listening such as a CD you would get stereo separation. Anyway that's the way I'm seeing it at this point.
    Phil
