clayton h
- Feb 24, 2004
Well frist off i would like to say hi to everybody iam new to this board, and to all this stereo stuff. Ok to the question, the stereo i have consist of c70 preamp, two m70 amplifers(all yamaha stuff) and a pair of klipsch klf 20 speakers. i would like to run each m70 on there own channel, the preamp has two set of preouts one normal the other inverted. In the yamahas book i would hook left normal to left input and left invert to right input on the left channel amp, then i would hook right normal to left input and right invert to right input on the right channel amp. Left channel speaker hook up from the left amp would be left + to left + and right + to left -, as for the right channel speaker hook up from the right amp it would be right + to right - and left + to right +. These amps are rated at 200 watts per channel into 8 ohms, and 250 watts per channel into 4 ohms. Is this called briding the amps into mono, what would the watts output be and would there be a possibility of hurting these amps. The speakers are rated at 200 watts continous, 800 watts peak into 8 ohms. Sorry for the long thread just want to make sure you all know what i talking about and trying to find out. Why iam doing this would like to have more power without spending more money.
thanks
clayton huff
thanks
clayton huff
