Lanny_B
- Nov 24, 2001
I'm remodeling my basement room for HT, and I'm a newb at this. I'd thinking about running the wires through the framing before sheetrocking the walls, but then I thought "What if I want to upgrade wires later, or change where things are?" So, is there a good way of doing this so that you can feed and unfeed wires through the walls later?
I thought maybe of running them on the outside of the walls, and then having a cover or something that covers them up - is there something like that? My wife suggested running them inside the molding, but I told her that wouldn't be thick enough. Plus, I'd like to be able to access it later.
