RobertCharlotte
- Feb 21, 2002
Hi, all!
I'm getting ready to wire up a room at work for surround sound, and my best option for running the wiring to the surrounds is to go up into the drop ceiling, through that space across the room (~ 30 feet), then back down. The ceiling has fluorescent lights which will normally be turned off when the surround sound system is in use. Budget is forcing me to keep the wire at about 16 gauge, I might be able to squeeze out enough pennies to go up to 14.
What issues do I need to worry about with this plan?
