Running cables from one room to another
Discussion in 'Accessories, Cables, and Remotes' started by Andrew_B, Jun 29, 2003.
  1. Andrew_B
    Andrew_B Stunt Coordinator
    Jul 30, 2000
    56
    I need to run some cables between rooms (specifically serial cables from a PC in a different room from my theater). My current solution is just a small hole in the drywall that is functional, but looks like crap. I've perused the aisles of my local home improvement store, but didn't see any faceplates that would fit the bill. What solution have you guys come up with when having to run cables between different rooms?
  2. Jay Yo
    Jay Yo Auditioning
    Jun 16, 2003
    4
    Blank wall plate drill hole to size. Use remodel cut in. In Portland try double O electronics.
  3. Andrew_B
    Jul 30, 2000
    56
    Great idea, Jay, thanks!
  4. anth_c
    anth_c Stunt Coordinator
    Jul 17, 2002
    79
    Andrew,
    Check out this site:
    http://www.rockler.com/ecom7/showoff...ectGroup_ID=20
    They offer grommets in various sizes and finishes (wood, plastic, brass) that are great for passing a cable through the wall. They have rounded edges to prevent snags. I have used them in the last three places I lived.
