Runco CRT wont display video, but grid good
Discussion in 'Displays' started by KevinBMiller, May 24, 2004.
  1. KevinBMiller
    KevinBMiller Auditioning
    May 24, 2004
    10
    Hiya
    Ok...Im new to this. Be patient with me. I have a Runco CinemaPro 760 CRT front projector (built 1996). The unit was removed from my friends home (worked fine at removal using S-Video converter to Y/C signal) and setup in my home with DVD player using the S-Video out.
    The DVD S-Video output is converted by a RUNCO S-Video to Y/C converter (BNC connectors) for connection to CP760 CRT unit's Y and C inputs [called "S-VHS" on back panel].
    I can get a clear test pattern (grid) and the menu to display on screen, but no source video will be projected. I have the rear selection set to "Y/C" and have also tried connecting a composite video out from DVD (yellow jack) to Runco's "Video-Input" BCN connection without success. I have switched it from all different settings "RGB, YC, and Video".
    Is there something that I am missing? The tubes all operate, look good and have low hours with no burn to be seen. Can anyone think of a reason source video is not projected?
    Any help GREATLY appreciated. Thank you.
    Kevin
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    You have a pm.
  3. KevinBMiller
    May 24, 2004
    10
    I finally took it to someone for a check up. Apparently the old Runco 760a is picky about video source. The DVD player I was connecting to didnt 'mesh' with the Runco. Setting the Runco up with a different DVD player (Panasonic) worked great on first try. Go figure.
    Thanks Chris for your help.
