baileymoto
- Jun 1, 2011
- Bailey J
Just bought a new house and I am looking for a way to use a closet for all my media. I prefer a very simple/minimalistic approach in the living room and would like to end up with simply a TV and no visible boxes. I'd hook up the xbox, cable box, etc to a switch inside the closet. I'd likely keep the HTPC (Mac Mini) on a glass shelf or something similar right under the TV.
This is a spanish/pueblo style home and is built on a concrete slab with a flat roof.. which means no basement, crawlspace, or attic. Fortunately, the TV and closet are on the same exterior wall and a relatively short distance from each other.
I was thinking that I could simply run an HDMI cable from behind the TV, then along the wall (outside), then back into the home and terminate inside the closet. I haven't measured yet, but a 50 foot cable would likely be more than enough...I'd likely be able to get a much short cable. I would probably put the cable inside some sort of conduit/PVC pipe and bury would I could. I'd plan on non of the cable actually being exposed to the sun.
This is in the southwest region (New Mexico) where it gets just a tad below freezing during the coldest part of winter nights and a bit over 100 during the hottest part of summer.
Here are a couple pictures of the setup and outside wall. You can see the closet to the right side of the picture (under the stairs and catwalk) What do you guys think of this idea? Any other suggestions?
