Run a stereo amp with different loads on each channel?
Discussion in 'AV Receivers' started by Aaron Howell, Jun 17, 2005.
  1. Aaron Howell
    Aaron Howell Stunt Coordinator
    Nov 19, 2003
    196
    I've read that running a single channel of a stereo amp can be harmful for an amp. I don't remember why, and I can't remeber where I read it to search. Is anyone familiar with this?
    At the same time, would it be harmful to run a different load on each channel? IE: running a mid off the right channel, and a tweeter off the left.
    Thx
    Aaron
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Could depend on the amp / design. Generally it is fine though, both of those scenerios.
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    For biamping, there are two methods - vertical and horizontal. Vertical is using one channel each from a stereo amp for each of the terminals on one speaker. Horizontal is using amp A to drive the mids, and amp B to drive the tweeters; supposedly to ballance the loads. The drivers draw the same amount of current either way, so I don't think it will make a considerable amount of difference with the average speaker.
  4. Aaron Howell
    Nov 19, 2003
    196
    Thx! That is exactly what I'm checking into. Just going over everything since I remember hearing the above. I could have sworn it was a member of the Cult forums, but searching it has come up with nil. [​IMG]
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    There are some essoteric(sp?) amplifier designs that this would probably not be a good idea. 99% of amps, it is no problem at all.
    Mismatched loads or not inputing any signal to one of the channel are generally fine.
