Rumble Filter needed with Sealed Sub?
Discussion in 'Home Theater Projects' started by Chris A H, Aug 20, 2003.
  1. Chris A H
    Chris A H Stunt Coordinator
    May 10, 2002
    172
    I have been looking for a plate amp, and it seems in my reading that a rumble filter is recommended mainly for ported subs.
    Is it recommended for sealed as well?
  2. David Giesbrecht
    David Giesbrecht Second Unit
    May 28, 2001
    306
    No, you can use one if you wish but it is not required especially if your going to be using it to drive something like a Shiva or Tempest. The sealed enclosure won't unload the driver below FB so over excursion with typical program material is unlikly unless your running an extreme amount of power through the sub.
    Personally I like the sub to receive the full fury of 10 hz subsonics because you can feel it and its a cool effect.
  3. AndersP
    AndersP Stunt Coordinator
    May 17, 2002
    53
    A rumble filter can be a very good idea if you plan to play vinyl with your sub. I see no use for it with digital sources.
