Rule of thumb for display elevation?
Discussion in 'Archived Threads 2001-2004' started by Kevin C Brown, Nov 13, 2002.
  1. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Say if my eye balls are 35 inches off the ground, I have a direct view TV set 8 feet away. How high off the ground should the set be?
  2. JJR512
    JJR512 Supporting Actor
    Dec 11, 1999
    619
    It was explained to me yesterday, by a seemingly very knowledgeable salesman at Tweeter, that your eyes should be approximately on the same plane as the center of the screen. So, the set should be high enough off the floor so that the center of the screen is, in your case, about 35 inches high.
  3. DaveF
    DaveF Moderator
    Mar 4, 2001
    18,266
    1,646
    9,110
    One Loudoun, Ashburn, VA
    David Fischer
    The obvious answer, to me, is as JustinR stated: the TV center should be at eye level.
    However, if films are TV shows are composed so that the important images are mostly at the top, then the TV placement should be skewed downward, to get the top closer to the center of looking.
    I think that's how my TV is (because of the stand height) so I think I'll stick with that explanation [​IMG]
  4. Kevin C Brown
    Aug 3, 2000
    5,712
    Thanks guys. When I was imagining the picture in my head, that kind of made sense too. Cool! [​IMG]
