Ryan T
- Sep 10, 2001
My brother can solve the 6X6X6 cube . I think he got his average 3x3x3 cube down to under a min.
Ryan
Ryan
For some unknown reason the colour placement (relative to each other) has been changed..That has always been the case. If you bought two cubes from different brands, the colours could be differently placed (relatively) or (partly) even be different at all.
Cees
So, no one else makes nifty patterns with their Rubik's Cube?Made .
Yes, I used to do that a lot.
Cees
It only seems that way.
Each and every cubicle of the big cube is unique. It can only go to one place for the solved position. So, if you solve the puzzle, the writing will be there automatically - always the same, the way they put it.True except for the center square, which can rotate. It was possible to solve the cube for the colors but still have the writing on the center square out of alignment (rotated) relative to the writing on the surrounding squares. I devised moves to rotate the center square without altering the positions of the other pieces.
centre pieces of course do not move (shift place) at all since they are the pivots, but they can be rotated aroundAbsolutely true. I forgot about the central pieces, because "normally" they play no role. Yes, it complicates things a bit!
Cees
