Rubber Washers for Flexy Rack--source for 3/4"?
Discussion in 'Archived Threads 2001-2004' started by MarcS, Jul 13, 2001.
  1. MarcS
    MarcS Stunt Coordinator
    Feb 24, 2000
    147
    Now that I've got all the other parts for my rack, I'm choking on the prices I've seen for 3/4" ID rubber washers (I'm using 3/4" rod).
    Should I expect to be paying .35-.50 per washer? Needing 40 washers, that'll cost me about $15 or more...
    I already checked McMaster...
    Suggestions?
    TIA
    Marc
  2. Brian Corr
    Brian Corr Supporting Actor
    May 10, 1999
    535
    I used washers for a garden hose. Bought a bag at Lowes for a few bucks. (In the plumbing dept.)
  3. MarcS
    Feb 24, 2000
    147
    But are they 3/4" ID? All the garden hose washers I found were 5/8" ID...
  4. Eric M L
    Eric M L Extra
    Nov 12, 2000
    18
    Don't know if this will work for you, but I've been thinking of just squirting on a layer of silicone sealant to the metal washers when I get around to building my flexy.
  5. MarcS
    Feb 24, 2000
    147
    Silicone sounds messy...
    I went to a hose and gasket shop at lunch, and they'll cut me some washers, but it'll cost .85 each !! (x40 = $34)
    I've already drilled my holes for 3/4" rods, don't know if I can go back to 5/8"--but I really don't want to pay $15+ just for washers--that's more than the wood cost...
    Oh well--what did everyone else do that used 1" or 3/4" rods??
  6. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    I purchased a sheet of neoprene (wetsuit material) and cut my own.
    Greg
  7. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    I just used nuts and metal washers on my flexys.
    Nuts and metal washers cranked down tightly will never vibrate loose.
    Why do you guys use rubber washers? I hope its not for vibration dampening because I can assure you that if you had a subwoofer strong enough to vibrate a flexy rack significantly then rubber washers will not help one bit.
    I guess my racks are not flexys because they are not flexible..rather they are as stiff as a brick.
    Do you really want a flexible rack?
    James' DIY speakers
    [Edited last by James W. Johnson on July 13, 2001 at 08:42 PM]
  8. Julian Data
    Julian Data Second Unit
    Oct 5, 1999
    408
    James,
    It's called "Flexible" cause you can adjust your shelves it's not named for "Stiffeness". [​IMG]
    I use neoprene washers with metal with mine.
    I might just dump the flex and build an enclosed case. Getting tired of dusting..
    Ugh..
    I know .. I know.. the dust still comes in.
  9. James W. Johnson
    May 26, 2001
    1,055
    [​IMG] ok thanks.
    why?
    James' DIY speakers
    [Edited last by James W. Johnson on July 13, 2001 at 11:18 PM]
  10. Ryan Hawke
    Ryan Hawke Agent
    Jul 10, 2001
    45
    I used metal washers and used a pair of crescent wrenches to tighten. It's not going anywhere. To save money on the washers, I just bought a box of them. I can't remember my total cost but it wasn't too bad. Good luck.
    --Ryan
  11. Julian Data
    Oct 5, 1999
    408
    James, here's why..
    Not to marr up the surface of the shelves.
  12. Brian_J
    Brian_J Second Unit
    Mar 3, 2001
    418
    That should not be a problem since the washer will cover whatever it mars. I just used metal, painted everything black which was a f***ing pain in the tail because the black comes off when you put on the bolts. Honey pine shelves with black rods and hardware is pretty sweet looking though!
    Brian
    Zed's Dead Baby...
    [Edited last by Brian_J on July 14, 2001 at 05:34 PM]
  13. Julian Data
    Oct 5, 1999
    408
    If you tightened hard enough you will put a indentation on the shelves, hence why I use neoprene washers in conjunction with metal washers.
    I refuse to put a dent onto my finish on the shelves. Too much work.
  14. Dan_D
    Dan_D Stunt Coordinator
    Jun 18, 2001
    98
    anyone have a pic of one of these handy? i wanna see
    [​IMG]
  15. Julian Data
    Oct 5, 1999
    408
    Dan,
    for a "flexi rack"?
    Check the HTF Archives. [​IMG]
  16. Mark Wilcock
    Mark Wilcock Extra
    Oct 18, 2000
    16
    I made mine out of an old car inner tube.
    I made the outer hole by sharpening a short piece of 1.5 inch tube and jamming it on the chuck of a drill press (not turned on). Then I put a bit of wood on the drill press base and pressed the washers out of the inner tube.
    The centre holes where cut with a round chisel.
    They don't really stop the rack vibrating, they just protect the finnish.
    You can see my rack atwww.bluemarine.com.au/mark
  17. Will Ernst
    Will Ernst Agent
    Mar 12, 2001
    28
    Wow Mark! That's one nice looking rack. I just finished mine, now I'm ready to scrap it and start anew! I can't really tell in the picture, did you opt for stainless hardware?
    -will
  18. Mark Wilcock
    Mark Wilcock Extra
    Oct 18, 2000
    16
    Nah, just zinc plated
