rta software
Discussion in 'Speakers & Subwoofers' started by Brad Russell, Oct 3, 2003.
  1. Brad Russell
    Brad Russell Stunt Coordinator
    Aug 13, 2003
    137
    Trying to take mesurments with my RS meter and ploting the readings is one of the most tedious things I have tried to do. Is anyone aware of som RTA Software that would allow me to hook up a mic to my computer and have it spit out the graphs?
    Brad
    PS I have a Mac G4
  2. Alan Howard
    Alan Howard Extra
    Aug 15, 2003
    17
    I'm not sure about the various RTA programs available but I do know that the few I looked at had some cool features. Have you tried punching your RS meter readings into excel. It's great for graphing and you can also have it correct your readings if you plug in the RS correction table.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    I use this, and highly recommend it. The demo version is free too:
    http://www.etfacoustic.com/
    Don't know if there's a Mac version though. [​IMG]
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I'm going to move this thread over to the speakers and subwoofers fourm. I remember there being a lot more discussion over there about RTA software.
  5. Mark Seaton
    Mark Seaton Supporting Actor
    Oct 10, 1999
    599
    110
    Mark Seaton
    True Audio also has RTA software which is quite reasonable in price. There are also some spectrum analysis software packages which work well for low frequency measurements.
    There are many packages available. It is mostly a matter of what you would like to be able to measure, and what you are willing to invest. Note that the RS Meter tends to have a lot of variation and is not terribly accurate as a microphone. Generally you can only be certain in accuracy to within a few dB. Certainly fine for level matching with the same test signal, but not for flatness and absolute levels.
  6. Mike Dzurko
    Mike Dzurko Stunt Coordinator
    Apr 11, 2000
    78
    I've used True RTA in a laptop. I also have ETF in that same laptop. Both are very good tools.
