Arron H
- Jan 17, 2002
I recently upgraded to B&W 805s/HTM2 and I starting to look at upgrading other components as well. I currently have a Yamaha RXV-1200 but am wondering if going to the Rotel RSX 1055 would be simply a lateral move or a true upgrade. If I went with the 1055, I would eventually want to get a RMB 1075 or 1095 and use the 1055 as a processor only. Here are some questions:
1. Is the move from my Yamaha to the 1055 a lateral?
2. How would the Yamaha work as a processor for the 1075 or 1095? This would seemingly be a less expensive upgrade path as I would not have to buy two new components by using the Yammy as a processor.
3. Should I be considering the 1066 as a processor replacement for the Yammy rather than the 1055? I have read some threads on this forum indicating that the 1055 & 1066 are preety comparable as far as processing is concerned.
3. What would you do if you were in my shoes
