RSP 1066 popping noise ?
Discussion in 'Archived Threads 2001-2004' started by Tartopomme, Oct 9, 2002.
  1. Tartopomme
    Tartopomme Auditioning
    Oct 9, 2002
    3
    Hi,
    I've an audible pop when switching between different formats. For example, when browsing a DVD menu in DD, if I change the audio option to DTS and start the movie, there's a pop when the DD turns off and DTS kicks in.
    Anyone have this problem ?
  2. rodneyH
    rodneyH Supporting Actor
    May 22, 2001
    844
    nope, no problem here
  3. Andrew_Ballew
    Andrew_Ballew Second Unit
    Feb 21, 2002
    294
    When I had my 1066, it had quite a few pops and clicks while doing various things. After living with the 1066 for a while, and thinking about it a lot after I sold it, I am more and more convinced that it really is not the holy grail that many have proclaimed it to be. At least not for me. Too many nagging little issues.
    Cheers
    Andrew B.
  4. Jim Mohr
    Jim Mohr Auditioning
    Jul 29, 2002
    9
    The only time I hear anything out of the ordinary is when I switch Cinema Equalization on/off ... and even then it is only sporadic.
  5. Arnold van Oostrum
    Sep 12, 2002
    33
    Tartopomme, could you tell which firmware version you are using. At first I had the same problem with my 1065, but today not anymore. So maybe one of the firmware fixed it.
    You can check your firmware version by holding down the MUTE button a couple of seconds until the firmware is displayed in the FL-display.
  6. Tartopomme
    Oct 9, 2002
    3
    My firmware is 2.2.0
  7. Arnold van Oostrum
    Sep 12, 2002
    33
    Same problem is reported here. Same firmware version also.
  8. Tartopomme
    Oct 9, 2002
    3
    Yes, it'me too [​IMG]
