RPTV's that can be divided into 2 pieces...
Discussion in 'Archived Threads 2001-2004' started by Ron_C, Jun 24, 2002.
  1. Ron_C
    Ron_C Agent
    Dec 6, 2001
    47
    Since the HT room is in the basement, i need to get a rptv down the stairs and around a tight corner, and i think to get a tv down there in the size i want, getting a tv that comes apart in pieces is the only way to go. What are some brands that do this? Thanks...
  2. errol
    errol Stunt Coordinator
    Dec 29, 1999
    150
    Hi ron,
    The Mitsu diamond line.
    Errol
  3. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    All 65" mits I believe. My 65819 comes can be broken down (platinum plus model)
  4. Andrew Woodward
    Andrew Woodward Auditioning
    Jun 18, 2002
    5
    Mits 65" WS-65869 comes in two pieces as well.
  5. Andrew Woodward
    Jun 18, 2002
    5
    After looking through my Mits product book These are the ones that can come apart. I might have missed some but I don't think I did.
    Gold Series:
    VS-70709
    Platinum Series:
    WS-65809
    Platinum Plus Series:
    WS-65819
    WS-65869
    Diamond Series:
    WS-65908
    WS-65909
    WS-73909
  6. David Cohen
    David Cohen Agent
    Nov 16, 2001
    38
    The new Hitachi- 65SWX20 also breaks down into two sections.
  7. LorenzoD
    LorenzoD Agent
    Mar 4, 2002
    48
    This reminds me of the NCC-1701D being able to separate...
    Seriously, though, are any of these models capable of functioning while apart? In other words, can you have a tabletop big screen?
    Not that I'd ever do this, but I was just bored and wondering...
  8. errol
    Dec 29, 1999
    150
    Hi Lorenzo,
    Not exactly sure about your question... but here it goes.
    No, the sets mentioned won't work if separated. Lower part houses the electronics and CRTs. The upper part holds the screen stack.
    r,
    Errol
  9. LorenzoD
    LorenzoD Agent
    Mar 4, 2002
    48
    Did the geeky Star Trek reference throw you off? [​IMG]
    But, yes, you answered my question...
