liana
- Oct 28, 2002
I have recently purchased the Hitachi 43FWX20B.
According to its specifications, it has the following options.
*1080i/540p User Selectable Display *1080i/720p/540p/480p/480i Input Processing
Now i read in another thread on this forum that this set up-converts 480p to 540p. This is all kinda new to me so bear with me. I have the Panny CP-72 5-disc dvd changer with a progressive scan output. From what i understand, progressive scan is 480p.
Does this mean that it will up-convert the resolution coming from the dvd player to 540p? If the answer is yes, wouldnt that cause a loss of picture quality, and if yes, then is it even worth it to use the progressive scan? I have a mental image of it stretching the picture i guess.
I also have a GC and PS2 i plan to hook up via component cables, as these systems are putting out games that can be displayed in 480p.
Thanks for the info!!
