RPTV to wall clearance: What's the minimum?
Discussion in 'Archived Threads 2001-2004' started by John Macri, Dec 16, 2002.
  1. John Macri
    John Macri Stunt Coordinator
    Sep 30, 1997
    93
    2
    10
    I need to place an RPTV as close as possible to the wall to fit my room. What's the minimum distance that's safe? The RPTV will have free clearance/airflow except for the close rear fit...
    Thanks...
  2. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    In my humble, uninformed opinion: zero inches. Just bang it right up against the wall, or as close as you can get with all of the cables you'll be running. The ventilation slots are in the top of the chassis.
    Jan
  3. Pete_K
    Pete_K Auditioning
    Nov 5, 2002
    On my Mits 65611 there is a bumpout on the back that forces a 4-5" stand off from the wall.
