Rptv Riser...
Discussion in 'Home Theater Projects' started by Brett Sw, Dec 10, 2003.
  1. Brett Sw
    Brett Sw Agent
    Nov 12, 2003
    31
    I just took delivery (Monday) of my new 51H83. Problem being...Due to room constraints I don't have room for a separate rack to house the other HT components. I'm thinking of builing a "riser" about 6-8 inches in height to set the 51 on. My vision is a riser that is either carpeted to match the floor or painted to match the silver of the TV. To keep the dust to a minimum, I'm thinking a smoke colored plexiglass access door that swings down to get to the gear. I'm a fairly accomplished carpenter, so making it look good is not the problem. QUESTION...Anyone built one or have any other ideas that I may not have though of? FYI...The wall/corner the HTS is on won't accomodate building a "cubby hole" in the wall to house the gear. Thanks...
  2. PhilBoy
    PhilBoy Second Unit
    Sep 30, 2003
    427
    How about a wall mount cabinet that runs the width of the room, but with a low profile.
    You could even position it to hold your centre channel speaker.
    ... or even a side wall cabinet.
  3. Brett Sw
    Brett Sw Agent
    Nov 12, 2003
    31
    Interesting...I'll take a look this eve when I get home. Thanks for the idea...
