RPTV loses settings after power failure?
Discussion in 'Displays' started by EricWT, Dec 11, 2003.
  1. EricWT
    EricWT Extra
    Mar 19, 2002
    16
    Hello,
    I have an RCA P52812, and I did a basic calibration with it using the Sound & Vision DVD (good improvement.) However, after a power failure the TV loses these settings. Now that I know how to do it, I can repeat after a failure. However, I am considering a better calibration, and I am worried that I will lose those settings too.
    Is this normal? And would the service menu settings be affected too?
    Eric
  2. Gilbert_P
    Gilbert_P Stunt Coordinator
    Dec 3, 2003
    53
    just write down your setting after you calibrate it. that should help if that happens again.
  3. EricWT
    EricWT Extra
    Mar 19, 2002
    16
    Thanks for the tip-- I will try that after I calibrate. Subsequently I have found that my setting were not getting reset; it was all me, as even by going into the menu to look at available presets it was wiping mine out. Oh well... :)
    Also, I noticed a comment somewhere (I think on this forum, but I am not sure) about changing the presets in the service menu to hold the basic settings that you choose. I think I will look for a parameter to do this, although as a total newbie I am not sure I will...
    Eric
