RPTV glass cleaning?
Discussion in 'Displays' started by Robert K, Dec 18, 2003.
  1. Robert K
    Robert K Agent
    Dec 8, 2003
    39
    I might try to squeeze some more time out of my 10 year old Sony XBR 57". It has some issues with fixed shadows in the display. Im thinking this may be due to dust accumulation inside on the lens and mirror.
    Is getting access and cleaning something I should attempt?
    I assume I can probably blow air over the glass to clean them from dust accumulation.
    any thoughts?
    Thank you
    robert
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Are you a qualified service personel??? lol
    Sounds corny, but true, and only you really know if you are or not.
    If not, I'd call somebody out to do it.
    If so, I say go for it, but I will tune in to this thread, and see how others suggest about doing it as well.
    Cleaning the inside real good, and cleaning all mirrors / lenses / crt surfaces is a large job on a big set.
    I consider myself qualified service personel, so I would personally give it a shot.
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
  4. Robert K
    Robert K Agent
    Dec 8, 2003
    39
    thats great. thanks. Ill give it a shot. Worse that can happen is I kill the TV. And after all, this all started about getting a new TV.
    thanks again
