RPTV furntirue
Discussion in 'Home Theater Projects' started by Dino_N, Jun 18, 2003.
  1. Dino_N
    Dino_N Auditioning
    Mar 13, 2003
    3
    i'm in search for a entertainment center furniture that can house my 55in HDTV. So far, i like the looks of the brige-like furniture. Can anyone tell me where to buy it for less than 500 bucks? i'm on a tight budget. Thanks!
  2. sean_pecor
    sean_pecor Stunt Coordinator
    Mar 5, 2003
    137
  3. David Preston
    David Preston Supporting Actor
    Mar 23, 2003
    698
    What type of finish are you looking for. If you are looking for a black finish check out the Bush one a Best Buy. It goes for $399. Thats what I got it matches the RPTV and black components well. You could try to haggle them like I did I told them if they give it to me for 350 I would take now if not I will go down the road because and get the one I like at their competitor. I would have too but they were willing to go $350. I wind up paying $360 because they were out of stock and I had to go to another store and they would only go $360. Still saved a few bucks. I'll try to get a link for you.
  4. David Preston
    Mar 23, 2003
    698
  5. David Preston
    Mar 23, 2003
    698
    Ok it works never tried that before. It looks much better in person. I would show you pics of mine but it will be the end of the month before I get pics.
