RPTV and digital cable box.
Discussion in 'Archived Threads 2001-2004' started by Chris_MJ, Jul 23, 2002.
  1. Chris_MJ
    Chris_MJ Agent
    Apr 29, 2002
    33
    I have a digital Cable Box hooked up to my RPTV. When I change channels there is a rectangle box at the bottom that shows what is on, the time, etc. I am sure you are familiar with it. Can this burn in the TV? It is not on all the time but when you change channels it appears. Over time can this cause burn in?
  2. DustinDavis
    DustinDavis Stunt Coordinator
    Dec 26, 1999
    171
    110
    If you forget about it and leave it on the screen then it might, but I wouldn't worry too much about it as long as you use it only to change channels. I have the same thing. It probably spends such a small amount of time on the screen it is not an issue.
