RP91 firmware upgrade
Discussion in 'Archived Threads 2001-2004' started by Jason Cole, Jan 2, 2002.
  1. Jason Cole
    Jason Cole Extra
    Sep 1, 2001
    21
    I thought I read something about this but a search doesn't bring much up. Is there a cd rom out there for this or am I making this whole thing up ? Any info would be helpful. I haven't even gotten mine from dealmountain yet, but this upgrade thing makes me nervous that I just blew $480 bucks.
    jason
  2. GlennH
    GlennH Cinematographer
    Sep 28, 1998
    2,132
    7
    110
    Glenn
    Here is the HTF thread:
    http://www.hometheaterforum.com/htfo...=RP91+firmware
    and the files can be found in links in this thread at AVS:
    http://www.avsforum.com/avs-vb/showt...threadid=96646
    By the way, I finally got around to burning the ISO image file to a disc last week and the upgrade worked fine on my player.
    Don't sweat your purchase. It's a great player. Check your firmware version when you get it (see instructions in the thread for how to do that) and if it's lower than 236 do the upgrade. You'll be good to go.
  3. george kaplan
    george kaplan Executive Producer
    Mar 14, 2001
    13,063
    2
    Back when this first started people who could burn the upgrade were offering to send it to the poor unfortunates like myself who can't, since once you've used it, it's basically of no use to you. Back then, I didn't ask for a copy cause I was getting ready to go out of town for a while on vacation. But now that I'm back, if anyone has a copy of 236 that they don't need and would like to send it to me, just send me a private message. Much appreciated. [​IMG]
  4. george kaplan
    Mar 14, 2001
    13,063
    2
    An offer has been made. [​IMG] Thank you.
  5. John Geelan
    John Geelan Screenwriter
    Oct 11, 2000
    1,087
    I just checked my RP91 and the screen says
    H088 50G188
    not sure what firmware this is.
    I may need a copy of that new firmware if one is available
    as I too don't have a burner at this time.
    JohnG:b
  6. John Geelan
    Oct 11, 2000
    1,087
  7. Steve Morgan
    Steve Morgan Second Unit
    Nov 10, 1999
    328
    Farm in Kansas
    Steve
    If anyone needs a Cd to upgrade to the 236 new version I have one that was sent to me and worked great. Let me know and its yours.I just ask that once used to, pay it forward!
    Cheers,
    Steve Morgan
  8. RoyGBiv
    RoyGBiv Stunt Coordinator
    Apr 10, 2000
    229
    John:
    The last three digits are the firmware number. So, your firmware version is 188. That is the one mine shipped with.
    You should upgrade to 236. It fixes the centering issue, and the pink tint when exiting the audio menu setup incorrectly. Others have said it does other things with the brightness/contrast, but I can't verify that.
    SMK
  9. Myram
    Myram Second Unit
    Aug 18, 2001
    292
    I will make copies for anyone who needs one, I have already been contacted by a few people.
    Email me for more details.
  10. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Is it possible to burn the firmware up to a CD-RW so that you could get some more use out of the CD-RW once you're done burning the firmware update?
  11. Jim Douglas
    Jim Douglas Second Unit
    Aug 2, 1999
    256
    3
    Patrick,
    I burned mine to a CD-RW disc and it worked fine. I then deleted the files and reused the disc.
    Later
    Jim
  12. Scott-C
    Scott-C Supporting Actor
    Jul 23, 2001
    863
    I heard that some people were having problems burning their firmware upgrade. Anything strange I should look out for when I try to burn mine? (I think I have a link to the instructions somewhere, so I'm just looking for tips that may not be in the instructions).
    Thanks!
  13. Steve Tack
    Steve Tack Agent
    Feb 15, 1999
    37
    I just upgraded mine from 155 to 236 and it works fine. (as others have run into, 4:3 material on mine used to be slightly shifted to the left - now it's severely shifted to the right. No big deal really though)
    I used the "Create CD From Image" option of the Easy CD Creator 4 software that came bundled with my CD burner and used the "disc-at-once" option. There really weren't any other options to set (and therefore few ways to screw it up!). I did burn it at 8x, since I used a cheapo CD-R disc that's only rated to that speed.
    It did take quite a long time for the update itself to occur, so my advice is to be patient. I didn't time it, but it seems like it took something like 10-15 minutes, which seems weird, but it eventually did finish.
  14. John Geelan
    Oct 11, 2000
    1,087
    I would like to thank Steve Morgan who has kindly agreed to send my a 236 firmware update for my RP91.
    I will post when the copy will be available to the next person who needs it.
    JohnG
  15. Jason Cole
    Jason Cole Extra
    Sep 1, 2001
    21
    I just got my player and the pic is already shifted to the right...the insert in the directions say hit pause, joystick to the left, hold it and hit stop. I do this but nothing happens. Any suggestions as to what I'm doing wrong. Will the upgrade fix this ?
    thanks
